Faulty rear indicator LED help needed please.
dt-tdi
Active Member
Crewe
Hi everyone.
I've got a faulty rear nearside indicator LED stiprip on my A6 saloon.
The faulty cluster is on the boot lid and affects a single line of LED's (see attached photo).
The rest of the LED's in the cluster are working.
I've attached the scan from VCDS for the affected module.
Any advice or help would be greatly appreciated.
TIA
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Part No SW: 4H0 907 064 EP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0521
Revision: 00002001 Serial number: 0333515896
Coding: 011F0E2280B900018320080400030E470000000000000000000000000000
Shop #: WSC 02391 785 00200
VCID: 7BF39B6DFA4C0555D7-802E
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93224122
2 Faults Found:
03192 - Lamp 2 for Blinker; Rear Left
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 161
Mileage: 110134 km
Time Indication: 0
Date: 2022.12.22
Time: 21:35:38
02198 - Bulb for Tail Light 2; Left (M49)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 110358 km
Time Indication: 0
Date: 2023.01.03
Time: 21:54:42
Swap sides & see what it does, but ones I've come across have been led PCB corroded water damaged.
Reactions: dt-tdi
All fixed now.
Dried the cluster out thoroughly with a hair dryer then left on a radiator over night.
Made a new foam seal and run a bead of clear silicone around the leading edge to hopefully eliminate water ingress.
Finally cleared fault codes via VCDS and rescanned.
All good so far :thumbs up:
