Racingline Stage 3 - Monoblock Big Brake Kit – 380mm Rotors & 6 Pot Calipers VW SEAT AUDI SKODA
Used on my 2021 Audi S3 for approx 15000 miles. Condition as per pics. Plenty of life left in discs and pads.
£2500
Part No: VWR650000 / BLK
Condition - Used – good
Racingline Stage 3 - Monoblock Big Brake Kit – 380mm Rotors & 6 Pot Calipers VW SEAT AUDI SKODA VWR650000 Racingline Stage 3 Monoblock Big Brake Kit – MQB Platform After almost a year of test and development work, the much-anticipated ‘Stage 3’ Big Brake Kit is now available in four colours and two rotor sizes for 18″/19″ wheels. Boasting a forged monoblock caliper, designed by us from the ground up using the latest FEA Technology we think it’s easily the most dramatic big brake kit on the market – but more importantly it performs like no other. With incredibly stiff monoblock construction, and the highest burst-pressure test ever recorded by Racingline’s development team, it’s no wonder that record 100kph-0 times are being produced.
The Racingline Stage 3 Forged Monoblock Brake Kit moves braking technology to a level above anything seen before in this market. The design vision was made possible by an advanced 5-axis CNC manufacturing techniques to give this kit more in common with top-level motorsport components than typical aftermarket parts. The result is a combination of ultimate track performance with lightness, stiffness and beautiful attention to detail. Each lightweight forged Monoblock caliper is a one-piece construction that starts out from an ultra-strong forged billet. Rather than two halves bolted together, our design takes a complex 5-axis CNC machining procedure to build, usually reserved only for the highest-specification motorsport kits. The result is a 6-piston caliper that is both stiffer and lighter than any other, combined with exceptional cooling characteristics and stunning detailing. Despite the size of these calipers, they weigh in significantly under the mass of the factory ones.
The caliper, pads and bracket assembly together weigh 5.3kg (11.7lb) vs 8.6kg (18.9lb) for the factory Golf 7R / S3 equivalent. The kit includes 380mm fully-floating ‘triple-grove’ two-piece discs giving vastly greater heat capacity, so reducing the effect of fade. Technical Specs Fully-Floating Disc Heat treated FC-25 two-piece Steel Carbon Rotors 380mm rotors (19” wheels) Sprung floating hardware for near silent running Vented ‘Triple Groove’ discs with break-in-surface as standard Fast road – Pad supplied with factory pad wear sensor AP pad shape for multiple pad options Goodridge ISO, TUV DOT and ADR approved lines Racingline’s hub adaptor system
What’s in the Kit? – Monoblock Front Brake Calipers (Pair) – Caliper Mounting Brackets (Pair) – Full Mounting Bolt Kit – Braided Steel Front Brake Line Set – Sport Brake Pad Set (Fast Road Use) – 380mm Fully Floating 2 Piece Brake Discs (Pair) Notes – Factory 19″ wheels and other brands may require spacers – Racingline and Revo 19″ wheels will not require Spacers CONFIRMED APPLICATIONS 380mm x 32mm kit: Minimum 19" wheel diameter required. Our Hub Adaptors recommended for use with factory wheels. 380mm VWR650000 BLK
VW Golf 8 2020+
VW Golf 7 & 7.5 2013-2020
VW Passat B8 2015+
VW Arteon 2017+
VW T-Roc 2017+
VW Tiguan II 2016+
VW Jetta / GLI 7 2018+
Audi S3 8Y 2020+
Audi A3 8Y 2020+
Audi S3 8V 2013-2020
Audi A3 8V 2013-2020
Audi RS3 2.5 TSI 8V evo 2017-2020
Audi RS3 2.5 TSI 8V 2015-2017
Audi TT 3 8S 2014+
Audi TTRS 3 2.5 TFSI 8S 2017+
Audi SQ2 2018+
Audi RSQ3 F3 2019+
Audi Q3 2019+
Audi Q2 2017+
Cupra Leon IV FW 2020+
SEAT Leon III 5F 2015-2020
Cupra Ateca 2018+
Cupra Formentor 2020+
SEAT Tarraco 2.0 TSI 2018+
Skoda Octavia IV NX 2020+
Skoda Octavia III 5E 2014-2020
Skoda Superb III 3V 2015+
£2500
VW Golf 8 2020+
VW Passat B8 2015+
VW Arteon 2017+
VW T-Roc 2017+
VW Tiguan II 2016+
Audi S3 8Y 2020+
Audi A3 8Y 2020+
Audi TT 3 8S 2014+
Audi SQ2 2018+
Audi RSQ3 F3 2019+
Audi Q3 2019+
Audi Q2 2017+
Cupra Ateca 2018+
