Would anyone mind looking at a vcds scan please?
quattrov6tdi
cork ,ireland
2019 Audi A8
I googled a lot but don't really understand so any help would be appreciated. None of these will clear even with bonnet up as advised on Ross site
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Coding: 07500143C13900CD070E87081FEF8C68131BB3110406009381000A00000196800845010200100000000001000005001B100200304001F107000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 74B1CFB01E314FCBFFA-8020
Wiper motor control module:
Subsystem 1 - Part No SW: 4N2 955 119 HW: 4N2 955 119
Component: WWS651 181010 052 0915
Serial number: 904753F0301828302796
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22301989X81A955555A0
Coding: 02005E
Light switch:
Subsystem 3 - Part No SW: 4N2 941 501 B HW: 4N2 941 501 B
Component: E1 - LTM H05 0053
Serial number: 18S17.04.1800300161
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE105101823610098
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4N0 947 135 CE HW: 4N0 947 135 CE
Component: Dachelektroni H42 0063
Serial number: 00000316700000000000
Coding: 100000
Adjustable Steering Column Control Module:
Subsystem 6 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA135527000060007727
Coding: 0A0700
Blower 1 for left front backrest:
Subsystem 7 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V512 LLR1SLvL H01 0012
Serial number: Q98AJ00220353
Blower 1 for left front seat cushion:
Subsystem 8 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V514 LLR1SKvL H01 0012
Serial number: Q98AI33854472
Blower 1 for right front backrest:
Subsystem 9 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V516 LLR1SLvR H01 0012
Serial number: Q98AJ00220354
Blower 1 for right front seat cushion:
Subsystem 10 - Part No SW: 4N0 963 575 HW: 4N0 963 575
Component: V518 LLR1SKvR H01 0012
Serial number: Q98AI33884875
Front windshield washer pump:
Subsystem 11 - Part No SW: 4N0 907 605 B HW: 4N0 907 605
Component: J1100/SWP H21 0015
Serial number: 00000000001835201468
Coding: 020000
Interior Light Module 2:
Subsystem 12 - Part No SW: 4N0 947 111 D HW: 4N0 947 111 D
Component: Dachelektroni H42 0060
Serial number: 00000317930000000000
1 Fault Found:
405507 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Function limitation due to energy management system]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:53
average_Voltage_terminals: 11.40 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 8.50 °C
interior_temperature: 13.00 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: On
Terminal activation-Term 75: qualification: OFF
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4N2 907 468 AL HW: 4N2 907 468 AB
Component: Gateway H14 0044
Revision: AB000002 Serial number: 028AB791618C21
Coding: 020100050004864073960000005B01325C98004018000000097D078E10000000
GVL: F1513C080844000002FC88000000C800110E0010000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 03539C6C4B9F7873F60-8056
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4N0 951 523 J HW: 4N0 951 523 J
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 4N0 915 181 A HW: 4N0 915 181 A
Component: J367-BDMConti H03 1050
Serial number: 7588540300190107001D
1 Fault Found:
8519683 - Energy Management Active
U140B 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:43
EM_vehicle_state: 02 1C
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 064 D HW: 4K0 035 064 A
Component: MU-H-LN-EU 046 2711
Coding: 0156010100000000C3110002000800302F0001E603F008008E
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 2517E2F4E56B6643B84-8070
Data carrier:
Subsystem 1 - Part No: V03 959 807 SF
Component: MIB2P_EU_Q121 0520
Multimedia System 1:
Subsystem 2 - Part No SW: 4N0 919 605 G HW: 4N0 919 605 C
Component: DU AU651 Top H43 0147
Serial number: INX00120101800040309
Compact disc data bank:
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000247420043
Multimedia System 5:
Subsystem 5 - Part No SW: 4N0 919 603 C HW: 4N0 919 603
Component: DU AU651 Bot H41 0147
Serial number: INX00112101800050779
Media Player 1:
Subsystem 6 - Part No SW: 4N0 035 123 HW: 4N0 035 123
Component: DISC PLAYER H06 0006
Serial number: AUZ8ZCJKJ00MQM0
Media socket:
Subsystem 7 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800786695012
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:49
Voltage terminal 30: 11.5 V
Status_Software_Version_Management-module_name: zFAS_Var_C_CL020
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 B HW: 4N0 907 660
Component: LASER_SCANNER H36 0202
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LaserScannAU651 013013
ROD: EV_LaserScannAU651_013.rod
VCID: 353732B455CB16C3084-8060
1 Fault Found:
11546627 - Laser for Adaptive Cruise
C12EB F1 [009] - Malfunction
[Heater_Resistance_too_high_error]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 11
Mileage: 117460 km
Date: 2023.02.03
Time: 22:10:47
Control Module temperature-Host: external temperature: 21 °C
Control Module temperature-Zynq: internal temperature: 37 °C
Control Module temperature-Host: internal temperature: 21 °C
Control Module temperature-Zynq: external temperature: 18 °C
Voltage terminal 15: 11.317 V
heating_resistor: 90.59 Ohm
heater-Medium power: 0.000 W
heater-Voltage: 0.000 V
heater-PWM value: 0 %
heater-Current draw (mean value): 0.000 A
Heating and cleaning management-Visibility: 0 %
Heating and cleaning management-Degree of contamination: 9 %
Heating and cleaning management-Heating status: 02
Heating and cleaning management-Cleaning status: 02
Outside temperature: 8 °C
They all seem to be low voltage codes. Your battery is only supplying 11.5V Either give it a good charge or replace the battery.
Reactions: quattrov6tdi and NHN
Yeap battery issue.
Did you hack your maps as it's got an svm error.
Yeap battery issue.
Nice one lads, cheers.
It's going to main dealer next week so I will get them to stick in new battery.
@NHN never hacked the maps, only have it two weeks. I am having an issue renewing subs with Audi for audi connect. Their tech team is working on it.
Also getting all updates for radio system next week so hopefully that will sort the error you spotted.
Just got it back from Audi and ran VCDS and got these faults now. Won't post entire scan just the modules with faults.
VIN: WAUZZZF81KN012661 License Plate: 191D
Mileage: 118070km-73365mi Repair Order:
Chassis Type: F8-AU65 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
61 6D 74 81 82 A5 AC BA BB BC C4 CA CC CD CF D6 D7 DE
VIN: WAUZZZF81KN012661 Mileage: 118070km-73365miles
VCDS
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
29-Left Light -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: Malfunction 0010
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DDVC) Labels: None
PartNoSW:4N0907401K HW:059907309L
Component: 3.0l V6 TDI H26 0001
Revision: CAH26--- CVN: 6E71653356070F8A8947E11D8947E11D00000000D6C3ECFE
Coding: 0A2A4012056E050334286000000400000000000000000000
Shop #: WSC 48110 004 1048576
ASAM Dataset: EV_ECM30TDI0114N0907401K 001001
ROD: EV_ECM30TDI0114N0907401K.rod
VCID: 323D09A8A4A501FB2D6-8066
VINID: 9D196AAAA58805B780042186046FA041F5
1 Fault Found:
4814 - Voltage Supply 1 for Control Module
U3501 00 [038] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 118070 km
Date: 2023.02.24
Time: 02:06:19
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 36 °C
Intake air temperature: 17 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 10.960 V
Unlearning counter according OBD: 40
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0 0 0 0 0
2 Faults Found:
B10CD 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 26
Mileage: 118070 km
Date: 2023.02.24
Time: 04:07:11
average_Voltage_terminals: 11.60 V
Outside air temperature sensor-Outside air temperature on CAN: 10.00 °C
interior_temperature: 11.00 °C
65828 - Databus
U1121 00 [008] - Missing Message
[Comfort system central control module: no signal/communication]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 66
Mileage: 118070 km
Date: 2023.02.24
Time: 02:02:06
average_Voltage_terminals: 12.20 V
Outside air temperature sensor-Outside air temperature on CAN: 9.00 °C
interior_temperature: 9.50 °C
Terminal activation-Terminal 75 status: OFF
Terminal activation-Terminal 15 status signal: OFF
Terminal activation-Terminal 15 via CAN: OFF
1 Fault Found:
U140B 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 26
Mileage: 118070 km
Date: 2023.02.24
Time: 04:07:01
Address 42: Door Elect, Driver (J386) Labels:* None
PartNoSW:4M1959793D HW:4M1959793D
Component: TSG FS001 0188
Serial number: YE007RKR26405
Coding: 001FDA0052010482A001B032
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_VW53.rod
VCID: 40D953601A09A36BAB2-8014
1 Fault Found:
196676 - Door Warning / Entry Lighting
B1775 01 [008] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 65
Mileage: 118021 km
Date: 2023.02.23
Time: 09:47:04
Address 52: Door Elect, Pass. (J387) Labels:* None
PartNoSW:4M1959792D HW:4M1959792D
Component: TSG BFS001 0188
Serial number: YE007RL401651
Coding: 001FDA005E010482A001B030
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_VW53.rod
VCID: 3FDB509C67F7DC93D28-806A
1 Fault Found:
B1775 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 25
Mileage: 118054 km
Date: 2023.02.23
Time: 17:30:17
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 24
Mileage: 118016 km
Date: 2023.02.23
Time: 09:38:14
Control Module temperature-Host: external temperature: 23 °C
Control Module temperature-Zynq: internal temperature: 39 °C
Control Module temperature-Host: internal temperature: 23 °C
Control Module temperature-Zynq: external temperature: 19 °C
Voltage terminal 15: 11.688 V
heating_resistor: 90.13 Ohm
Heating and cleaning management-Degree of contamination: 59 %
Outside temperature: 14 °C
