How to remove fog light panel / grill to replace bulb?
2705gemini
Aberdeen
How do you remove the fog light panel to change the fog light bulb? I don’t want to break anything by pulling at it incorrectly
get low down and you'll see the screws holding them in. loosen and pull
Thanks but there’s no screws holding the panel / grill / insert (or whatever it’s called). It’s all clips. I couldn’t find the methodology for removal anywhere, my A6 owners manual doesn’t show the exact panel / grill / insert for the Allroad. I managed to get it off however by working around it prying the plastic bit by bit, I loosened it enough to pull out and to the side. Then removed the two torx screws holding the fog light unit in place that were inaccessible until the fog light panel was off. Can’t see any videos for the model in question and just didn’t want to break the ‘arrow’ clips by not knowing the technique required.
Reactions: pelhamsdetailing
