im not disputing it for a second simch, but can you explain how a sticking piston kills a turbo? ive heard it mentioned before, and im not sure how it happens.
does it stick open or shut? i assume its through the piston expanding due to mega heat?
if it sticks shut, then surely you will just get compressor stall? which although bad for a small turbo, isnt going to kill a big IHI all that fast is it? ive known people running no dv or BOV on some BT cars (non vag) and claim that the compressor stall isnt a problem as the turbo is so big and can take it.
if it sticks open, then surely you just get no boost? or is this the problem? that theres no boost yet the turbo will be spinning out of control anxd no pressure to open the wastegate and save it>?
having heard so many stories about the bosch valves splitting, even on standard cars (i know mine was fecked!) would it not make more sense to run a DV cold side relocation kit? im about to fit one to my A3 when i fit my ko3s. my charge pipe at the back of the bay gets far too hot to touch at all, and so does my forge DV.
with a decent FMIC and a cold side kit, the dv should never get anything more than luke warm at all.
glen said it certainly helped him with sticking DV's after relocating to the cold side.
