vaggy burger
johnyj
can any one help locate this in the engine
i run vag.com and it said i need one of these
Barometric Pressure (Altitude) Sensor (F96)
i have ordered it from the stealers but they couldnt tell me where it is
I searched Elsawin and took a guess at your engine code being a 1.8T AEB.
On this engine
The altitude sender is located in the electronics box next to the Motronic control unit.
The Motronic control unit is located in the large black box to the right of the battery as you look at the engine bay.
If you post up up your engine code I'll see if it makes a difference to the location.
this is what it printed out
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 558 E
Component: 1.8L R4/5VT MOTR HS D03
Coding: 04001
Shop #: WSC 06335
1 Fault Found:
00528 - Barometric Pressure (Altitude) Sensor (F96)
06-10 - Signal too High - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
does this mean theres something wrong with the abs aswell?
You've got a 1.8L motor so the location of the barometric sensor is as per my post.
With the ABS it says "No fault code found" so no you don't have a problem. The info is just the type of ABS controller
nice one hope this sorts my problem out.
used vag-com on mates g60 carrodo and all that came up was abs no error so im it means no probs with hes
cheers
16
I
795
31
7K
930
