Dreaded Cylinder 2 Misfire P0302 2.0T FSI
shaz
yorkshire
Hi guys, I have a audi a4 2007 2.0tfsi got the dreaded cylinder 2 misfire P0302 implausible signal,
so far Iv had new spark plugs fitted, and swapped the coils over to see if the code moves over to another cylinder but it still says on cylinder 2
today I had a compression check done on all the cylinders and it was the same across all four approx 120psi which is fine.
So I’m led to believe it could be a faulty injector?
has anyone had the same issue / fault code…?
many advice greatly appreciated
try swapping around an injector.
also, some you have done already though.
  • Faulty spark plug 2
  • Clogged or faulty fuel injector 2
  • Faulty ignition coil 2
  • Fuel injector 2 harness is open or shorted
  • Fuel injector 2 circuit poor electrical connection
  • Ignition coil 2 harness is open or shorted
  • Ignition coil 2 circuit poor electrical connection
  • Insufficient cylinder 2 compression
  • Incorrect fuel pressure
  • Intake air leak
