I am new here. I have had a faulty abs pump problem, which is very common in Saudi a4 b9 . after getting it removed I sent the abs unit to "ecutesting". and after receiving it back, I called a mechanic to fix it, now I don't have any light on the dash whatsoever, but there is a problem. after bleeding brakes each wheel and spending 2 hours. brakes are not working, the pedal is soft as anything, we even changed the servo sensor beforehand. and there is a hissing sound coming from the master cylinder. I am completely baffled and don't know what to do, the mechanic said it could be the master cylinder leaking and we have to replace it, but he is not entirely sure about it. please help
thank you
thank you
