Q5 Q5 fault code p2453
pedro61163
ABERDEENSHIRE
Looking for advice- friends engine management light came on in his Q5 45 TFSI, scanned with VCDS and its reading fault code P2453
Chassis Type: FY-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 22 29 2B 39 42 44 46 52 5F 6D 80
81 A5 BB BC D6 D7
VIN: WAUZZZFY5K2055935 Mileage: 38001km-23612miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
80-Batt. reg. aux. accum. -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DNTA) Labels:. 06K-907-425-V1.clb
Part No SW: 80A 906 259 E HW: 06L 907 425 C
Component: R4 2.0l TFSI H15 0003
Revision: --H15--- CVN: EB3FB2E7
Coding: 2A6540322526052B74082000000000000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TFS02080A906259E 001004
ROD: EV_ECM20TFS02080A906259E.rod
VCID: 2D070DA6BD91838294D-8078
VINID: 9D196AAAA5A915B080145243146FFBD134
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V544KJS1 H12 0109
Serial number: 20181125020103052426
1 Fault Found:
40561 - Particulate Filter; Differential Pressure Sensor
P2453 00 [175] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 37824 km
Date: 2023.06.08
Time: 17:02:23
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 21 °C
Intake air temperature: 23 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.972 V
Unlearning counter according OBD: 40
FAC_TPS_1_SAE: 18.750000 %
FUP_H_SAE: 13180.0 kPa
MAP_MES_SAE: 99 kPa
Engine: operating status: ES
TAA: 15.000 °C
T_AST_SAE: 0 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 80A 927 155 AN HW: 0HK 927 156 B
Component: 0CJ 20TFSIRdW H01 0003
Revision: --H01--- Serial number: 0000002937 CVN: D425E0CE00000000
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU49.rod
VCID: 75B7E5C615418B422CD-8020
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180327001312
No fault code found.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 80A 907 379 AB HW: 80A 907 379
Component: ESP9 Plus H11 0777
Dataset Number: 80B909504AC 0004 CVN: B9ED792D
Coding: 48AA40BE2CA70A9B91A7589420825292F5B5D212023450891A044A49AFAD4B
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 6FBBD7AE771DB192E61-803A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 N HW: 80A 820 043 N
Component: Klima Zone 3 H60 0251
Coding: 640900095544440D02000100080000000000000000000000000000000000
ASAM Dataset: EV_AirCondiBHTCAU491 001013
ROD: EV_AirCondiBHTCAU491.rod
VCID: 2809FCB29273A6AA67B-807C
Fresh air blower control module (front):
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002736085
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: CB31595900PAG0MUFU02
Rear air conditioning block 1:
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 DG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0313
Dataset Number: 80B909514K 0039
Coding: 07501143E17900CD050587149FAE80F9110B3108000000000000000020001A810A450122025601
ASAM Dataset: EV_BCM1BOSCHAU736 019008
ROD: EV_BCM1BOSCHAU736_019.rod
VCID: 03538B1E4B95A5F2129-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 80C 955 119 A HW: 80C 955 119
Component: 426 RL 181110 040 0581
Serial number: 00000001811062102075
Coding: FFC7F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22205037X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 15 01 2019 90150405
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE118121823811024
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 80A 947 135 G HW: 80A 947 135
Component: Dachmodul Q5 H32 0330
Serial number: Q00051083
Coding: 0D0104
Control head for driving and comfort functions:
Subsystem 6 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2819000009962004
Coding: 000000
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 N HW: 80A 959 655 N
Component: AirbagVW30 051 0605
Serial number: 003WBM08R9J2 Dataset Number: 80A909602H 0003
Coding: AACCF0C00CA00000585400FFF08C400000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_001.rod
VCID: 3E253AEA60F7081A3D7-806A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 001 209 18
Component: SideSensor_Df 001 0887
Serial number: 3570000000080049F13C
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 000 509 18
Component: SideSensor_Pf 001 0887
Serial number: 35800000000E02651236
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 031 209 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C10318C4912BD1
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 031 209 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C143D125C0180U
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 031 411 18
Component: FrontSensor_D 002 0149
Serial number: 355001C1440DFC50EC9T
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 6 - Part No SW: ----------- HW: 480 031 411 18
Component: FrontSensor_P 002 0149
Serial number: 356001C1440E34711AC2
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 7 - Part No SW: ----------- HW: 480 032 011 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C143EC2D40DC9J
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 8 - Part No SW: ----------- HW: 480 001 511 18
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000067A8DC4BP
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 9 - Part No SW: ----------- HW: 480 001 511 18
Component: PedPSensor_P2 001 0887
Serial number: I0N000000002049DC4BA
Coding: 2D2D2D
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 020 811 18
Component: CentrSensorXY 000 0108
Serial number: I0O0001B924E9844874+
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 80A 907 129 BE HW: 80A 907 129 BE
Component: Lenks.Modul H02 0005
ASAM Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 6C81C0A2460B4A8AC33-8038
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 80A 920 970 B HW: 80A 920 970 B
Component: MMQ5T19BENUK H05 0612
Revision: 0612v1.0 Serial number: 0FRA9104L18U
Coding: 25A48ED4A88006000123E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001032
ROD: EV_DashBoardAU736_AU49.rod
VCID: 2615F28A9867B0DA557-8072
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 8W5 907 468 H HW: 8W5 907 468 G
Component: Gateway H43 0144
Revision: AS000001 Serial number: 018AS507718A20 Dataset Number: 80B909515H 0059
Coding: 02010001002086402987000000590032483A0007100000000175078E10000000
GVL: 01D03C0008000200408C08000000C80000080000004000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003170
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4EC56A2AD057989ACD7-801A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 80A 951 523 D HW: 80A 951 523 D
Component: J453 MFL H06 0004
Serial number: 20190111101317 00478
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Component: J367-BDMHella H10 9070
Serial number: 1382026300
1 Fault Found:
9457921 - Backup Battery
B1916 04 [009] - Internal System Fault
Freeze Frame:
Fault Priority: 4
Mileage: 24426 km
Date: 2022.06.26
Time: 14:28:53
Voltage terminal 30: 12.30 V
Address 22: AWD (J492) Labels:* Redir Fail!
Part No SW: 80A 927 755 HW: 0CJ 927 749 A
Component: Q5_DL3_N_SD5H01 0006
Serial number: 18321A1303
Coding: 110F0000
ASAM Dataset: EV_AWDCQUOD31 001048
ROD: EV_AWDCQUOD31.rod
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 80A 907 397 B HW: 80A 907 397 B
Component: LCM_MLBevo H07 0022
Dataset Number: 80B909519C 0010
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 2E050AAAB097F89AAD7-807A
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 18000270993013
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_AU49.rod
VCID: 343118C25EBBD24ADB3-8060
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Dataset Number: 80B909520D 0011
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 8W1 959 593 D HW: 8W1 959 593 D
Component: TSG FS001 0188
Serial number: CLSM1RLK00I84 Dataset Number: 80B909872E 0034
Coding: 001F8A015001040000001002
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_AU49.rod
VCID: 4CC16022264BAA8AA33-8018
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4N0 909 144 D HW: 4N0 909 144 A
Component: EPS_MLBEVO2BS H21 0504
Dataset Number: 80B909852J 0004
Coding: 90002001010000
ASAM Dataset: EV_EPSVWBSAU426 009015
ROD: EV_EPSVWBSAU426_009.rod
VCID: 313F11D6A1A9E762B05-8064
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 CM HW: 4N0 907 064 M
Component: BCM2 MLBevo H14 0164
Dataset Number: 80B909501H 0038
Coding: 013500002FB100406309A0000400980213020010804306502F00000000040030001F0001000010
ASAM Dataset: EV_BCM2CONTIAU651 009009
ROD: EV_BCM2CONTIAU651_009.rod
VCID: 7CA1F0E2366BDA0A533-8028
ID - sensor:
Coding: 000000
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY182531N1P
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000045859651
Rear spoiler control module:
1 Fault Found:
65573 - Databus
U1121 00 [008] - Missing Message
[Transmission control module: Getriebe_11: no signal/communication]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 173
Mileage: 36919 km
Date: 2023.05.19
Time: 16:28:40
Supply voltages-Terminal 30 power supply: 12.506 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.569 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.569 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 02 18
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 8W1 959 592 D HW: 8W1 959 592 D
Component: TSG BFS001 0188
Serial number: CLSM1RLK00KP6 Dataset Number: 80B909873E 0034
Coding: 001F8A015C01040000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_AU49.rod
VCID: 4BC3633E2345ADB2AA9-801E
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8W0 035 192 K HW: 8W0 035 192 A
Component: MU-HS-LND-EU 050 0235
Serial number: Dataset Number: 80B909545R 0028
Coding: 01240601FF0A000053111101000A00102F0019E601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP.rod
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 LD HW: -----------
Component: ECE 2019 --- 0038
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 80A 919 604 A HW: 80A 919 604 A
Component: AU426_DU_STD H43 0009
Serial number: AUZ8Z9JHU00ABE
Multimedia system control head:
Subsystem 3 - Part No SW: 80A 919 614 A HW: 80A 919 614 A
Component: ControlUnit_B H20 0200
Serial number: AMXAM106121800010065
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0170
Revision: -------- Serial number: A2-C748-5750-7 Dataset Number: 80B909541D 0010
Coding: 0710
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_AU37.rod
VCID: 4ACD663A2C3FB4BA91F-801E
Address 80: Batt. reg. aux. accum. (A1) Labels: 8W0-915-101.clb
Part No SW: 8W0 915 101 A HW: 8W0 915 101 A
Component: MQ-BMS H20 0126
Serial number: 18000072321002
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80C 713 041 N HW: 80C 713 041 N
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20181220000876
ASAM Dataset: EV_GSMWaehlZFAU736 001017
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 290FF9B689799FA2785-807C
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 B HW: 80A 907 217 A
Component: BVS H17 0052
Dataset Number: 80B909466D 0023
Coding: 0404020600000401024023A0A50000FE00F0C020C020
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 2517F586E561BBC25CD-8070
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0188
Serial number: CLSM1RLS006Y1 Dataset Number: 80B909897E 0034
Coding: 000F88000001040000001000
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHKLO.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS003 0188
Serial number: CLSM1RLS006XV Dataset Number: 80B909896E 0034
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 80B909471B 0004
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 176BCF4E2F0D1952DE1-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
Dataset Number: 80B909472B 0004
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
