After loosing coolant on a weekly basis I knew this job was on the list.
Not a problem, with the excellent guide provided by Rob, all the tools on hand 2x of each required part ordered, just in case
Started to get on with the job yesterday, it's fiddly and access was tight but I kew that so what could wrong?
All of the cable ties around the vacuum pump were cut so I assumed someone has been in here before. The problem is
that someone has stripped the head of the bottom vacuum pump bolt!!!!
I gave up for the day after changing the coolant sensor for a new one with a new o-ring and clip as it looked like the source
of the leak.
So the question is. Can the flange be changed without removing the vacuum pump?
of the leak.
