Over the course of the last 4 weeks of owning the car I have noticed two things . Mostly on the front but slightly on the rear as well, there is uneven wear on the discs. No lipping but certainly a section that seems to be uneven. Also the feel through the brake pedal on the fronts is not as good as I expect so I imagine the pads/discs are past their best.
So looking at options and after some advice . On the front are factory Brembo floating two part. Not sure what pads. Now for the fronts I could do
Option 1. Replace entire assembly, pads and discs with ebay , roughly £700. https://www.ebay.co.uk/itm/15294383...IAiLzV/XxiGBA4fRFe+Bea2CNg==|tkp:BFBM3ML1yaRi
Option 2. Replace just the discs using my existing bells, with new OE bolts etc. I favour the j Hook design from Reyland. http://www.reyland.co.uk/audi-front/
These are £374 but I would need to source some pads. So the question is what is the best pads for fast road ( no track) , they suggest anything but Ferodo.
The backs I will tackle later
cheers
cheers
