alex_baker
Hi all, I thought I'd update the forum on my experience with the S4 I bought a couple of weeks ago.
Settling into my first Audi and coming from BMW's, I'm really enjoying the refinement and general build quality of the B8 S4 Avant. It's a lot of car for what I paid (£9.6k). It's on 117k miles with high spec (drive select, sports diff, electric tailgate, red & black sports seats, electric heated folding mirrors, pano roof, sun blinds, B&O sound system, nav, heated electric seats up front, garage door opener, adaptive xenons, etc).
I got £1200 off the asking price of the car because the seller (who hadn't had the car long at all and buys / sells cars as a semi-retirement hobby) and I agreed that after toothcombing the service history, things weren't done that probably needed doing. E.g. there was no record of the control arms ever being replaced, and the gearbox was only recorded as having had one service at around 110k miles. It was also due a major service and hadn't been used regularly in a year or so.
Test driving before I bought didn't reveal any clunks from the front end, or any gearbox issues whatsoever. As is tradition though, as soon as I got the car home and started using it I noticed clunking on full lock at the front end, as well as a few gremlins with the gearbox (judder on a hill start once, sometimes hesitates going from P or N to D). Otherwise the S-Tronic worked perfectly on manual mode and with the kickdown, etc, with no clunks when put under load. I also noticed a slight hesitation or misfire on cold start first time of the day. Only does it once a day if used every day.
I took it into Euro Performance in South Wales last week to have a major service done. I took the tech out to a nearby hill to try and replicate the S-Tronic hill start judder which we couldn't replicate, so that was a good sign ref clutch wear. When I left though, he experienced a gearbox fault message on the dash (not done that since I've had it).
Here's what's wrong with the car and needs doing:
-Gearbox: they read the fault codes and saw U010100 - Lost Comms with TCM (passive / sporadic), P174000 - Clutch Temp Monitoring (passive / sporadic) - along with a few other non-gearbox related past faults in the car's memory.
-Suspension: As suspected, upper and lower control arms could all do with replacing up-front. Brake reaction arm bushes are fine for now, although one is starting to show very early signs of perishing
-Engine: They noted 1 non-genuine no-name coil pack which could be the reason for the misfire. The power steering pump is also leaking, which was noted from a £6k bill I have for the car when it had the timing chains / guides and other things replaced at Volksmaster. They fitted a new PS hose but the pump itself seems to be leaking
-Other stuff: Slight oil leak from the diff output seal, but very slight weep - not major. Both rear coil springs corroded but not impacted structurally
So far to replace control arms, carry out a major service (with brake fluid change) and investigate the gearbox faults I'm the best part of £2.5k deep in repair costs!
Not the most ideal start to S4 ownership, but I really do hope the gearbox issue is not a major wallet killer. So far I have to say that Euro Performance have been fantastic.
Oh and PS: When I dropped the Audi off at EP, my partner followed me in my E46 and on the way home, the throttle position sensor decided to die on us, so I'm currently without a car until my £308 throttle assembly from BMW arrives and I can fit that....
