Jacobwatersx
had the car scanned after getting ABS and headlight levelling fault (both come and go at the exact same time).
noticed a defective fault under instruments? And also abs module is mentioned under Address 55: Headlight Range, how can these have anything to do with each other?
just wondering if someone would be able to have a look and see what they make of it, any help appreciated! Will post scan below, a lot of random faults as I’ve had the radio out so ignore those.
VIN: WAUZZZ8P2BA085808 License Plate: HW60BFF
Mileage: 195360km-121391mi Repair Order:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 61 77
VIN: WAUZZZ8P2BA085808 Mileage: 195360km-121391miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number: AUX7Z0J9FNS08D
Coding: 0143000C18070060
Shop #: WSC 06314 000 00000
VCID: C1CAE42C98E2FE9B0C-8094
VINID: 9D196AAAA220092440205200209678D5C4
3 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 - - Intermittent
Freeze Frame:
Fault Status: 00101111
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 36.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.319 V
U1017 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 195354 km
Time Indication: 0
Date: 2023.06.12
Time: 15:51:33
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 54.0°C
Voltage: 12.319 V
U1017 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 47.0°C
Voltage: 12.573 V
Readiness: 0010 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13424012492A00FFC81302E492210081380800
Shop #: WSC 19482 000 1048576
VCID: F5A240FC5CAA023B60-80A0
4 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 70
Mileage: 195298 km
Time Indication: 0
Date: 2023.06.09
Time: 22:35:27
Freeze Frame:
Count: 3
Count: 6
Count: 12288
Count: 128
Count: 42752
Count: 0
Count: 65280
Count: 0
03841 - RPM Sensor Rear Left: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 78
Mileage: 195354 km
Time Indication: 0
Date: 2023.06.12
Time: 15:51:31
Freeze Frame:
Count: 1
Count: 2
Count: 12288
Count: 71
Count: 44544
Count: 65280
Count: 1792
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 9
Reset counter: 39
Mileage: 195288 km
Time Indication: 0
Date: 2023.06.09
Time: 16:58:21
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 67
Count: 51457
Count: 258
Count: 64512
Count: 0
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 39
Mileage: 195290 km
Time Indication: 0
Date: 2023.06.09
Time: 17:03:27
Freeze Frame:
Count: 16387
Count: 0
Count: 12800
Count: 64
Count: 50944
Count: 255
Count: 1280
Count: 768
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000762 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: F8BC49C88BB87F537B-80AC
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 4E000A2FA005F000207041E00000094C421E25AA304DD928E4000E840041
VCID: B83C89C80B38BF53BB-80EC
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
3 Faults Found:
00059 - Terminal 30 for Interior Lighting
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:43:18
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
Term 50 Off
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:21
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:22
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36831031500256
Coding: 000003
VCID: C8DCF9087BD8CFD3CB-809C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB009HA6S Dataset Number: 8P0909602M 0004
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: CFEED21496B618EB8A-809A
Crash sensor for side airbag: driver side:
Serial number: 34928RB400005E2E97A0
Front Passenger's Side Airbag Crash Sensor:
Serial number: 35028RB400005E260056
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005E2E904N
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400005E2FA1CZ
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005EB5083Q
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005EB5185U
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
VCID: C6C0F730B1CCD9A339-8092
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 Q HW: 8P0 920 982 Q
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2249J004004962
Coding: 0260428
Shop #: WSC 12345 067 57207
VCID: C7DEFA34B6C6C0ABC2-8092
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 111694 km
Time Indication: 0
Date: 2015.01.26
Time: 11:20:38
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 250511F1001628
Coding: 350101
Shop #: WSC 19489 000 1048576
VCID: B73E8AF40626B02BB2-80E2
3 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:22
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:21:57
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 79
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:21:57
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0J9FNS08D
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 010202
Shop #: WSC 06314 123 12345
VCID: F4A47DF857D01B3357-80A0
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:07:59
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000564
VCID: C9DAFC0CA0D236DBD4-809C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: B12AB4EC28426E1BFC-80E4
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 32
Reset counter: 79
Mileage: 195362 km
Time Indication: 0
Date: 2023.06.12
Time: 19:26:47
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 44.0°C
RPM: 1152 /min
Speed: 14.0 km/h
Speed: 14.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0000564
VCID: CAD8C300A5D43DC3DD-809E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: BC3495D8FF0093735F-80E8
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 79
Mileage: 195288 km
Time Indication: 0
Date: 2023.06.09
Time: 16:58:25
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 0322085A
VCID: F1AA74EC28C22E1BBC-80A4
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650242601
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005250484
Coding: 0011422
VCID: F4A47DF897D01B3357-80A0
2 Faults Found:
02503 - Output Wire to Radio
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 34
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:22:34
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:07:59
End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.5V)-----------
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 23
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 40.0°C
Temperature: 36.0°C
Voltage: 12.319 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 195354 km
Time Indication: 0
Date: 2023.06.12
Time: 15:51:33
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 54.0°C
Voltage: 12.319 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 47.0°C
Voltage: 12.573 V
Revision: 00H31001
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 70
Mileage: 195298 km
Time Indication: 0
Date: 2023.06.09
Time: 22:35:27
Freeze Frame:
Count: 3
Count: 6
Count: 12288
Count: 128
Count: 42752
Count: 0
Count: 65280
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 78
Mileage: 195354 km
Time Indication: 0
Date: 2023.06.12
Time: 15:51:31
Freeze Frame:
Count: 1
Count: 2
Count: 12288
Count: 71
Count: 44544
Count: 65280
Count: 1792
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 9
Reset counter: 39
Mileage: 195288 km
Time Indication: 0
Date: 2023.06.09
Time: 16:58:21
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 67
Count: 51457
Count: 258
Count: 64512
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 39
Mileage: 195290 km
Time Indication: 0
Date: 2023.06.09
Time: 17:03:27
Freeze Frame:
Count: 16387
Count: 0
Count: 12800
Count: 64
Count: 50944
Count: 255
Count: 1280
Count: 768
Revision: 00107 AF
Coding: 00DD13
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:43:18
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:21
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:22
Freeze Frame:
Term 15 Off
Voltage: 12.25 V
OFF
ON
Term 50 Off
OFF
OFF
Coding: 000003
Coding: 0004012
1 Fault Found:
01304 - Radio
Coding: 0260428
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 111694 km
Time Indication: 0
Date: 2015.01.26
Time: 11:20:38
Coding: 350101
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:44:22
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 34
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:21:57
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 79
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:21:57
Revision: 00000000
Coding: 010202
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:07:59
Cannot be reached
Coding: 0000564
Revision: 00H17000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 32
Reset counter: 79
Mileage: 195362 km
Time Indication: 0
Date: 2023.06.12
Time: 19:26:47
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 44.0°C
RPM: 1152 /min
Speed: 14.0 km/h
Speed: 14.0 km/h
Count: 0
Coding: 0000564
Coding: 0000013
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 79
Mileage: 195288 km
Time Indication: 0
Date: 2023.06.09
Time: 16:58:25
Address 56: Radio
Cannot be reached
Coding: 0322085A
Coding: 0011422
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 34
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.09
Time: 23:22:34
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 70
Mileage: 195305 km
Time Indication: 0
Date: 2023.06.10
Time: 14:07:59
