This has been most helpful! I'm glad you are willing to take the time to get back on here and reply back with your findings. The wiring situation you have going on is very unfortunate, it's a shame you had to find out this way too, because the car is basically dead until its properly fixed. I apologize about being so slow to respond, I've been so busy with work, as well as other projects that need my immediate attention. But, I wanted to share a bit more of what I've done to my baby and where I currently stand.
(I wanted to mention this last week when I first came across your post, but ran out of time to explain everything single thing I've done so far) but here it goes...
When this fault started occurring on a normal basis, I ran a full scan and I did have a few DTC's that I've never seen on this car before (I will attach screenshots of the codes below.) So, with these specific fault codes present, and using process of elimination along with not being able to find anything on the internet regarding my concern, I removed my Steering Column Lock Module and sent it off for repair, along with my BCM2 and the key to the car. It wasn't cheap, mind you. But, I've still spent about half as much as I would've if I took it straight to the dealership.
I've been a technician at automotive dealerships as my prior career, 13 years, by the way, and I've seen many times where technicians do not take the proper diag steps as they should, and will basically start 'throwing parts' at the car at the customers expense. In hopes that what ever they replace will 'fix' the customer's concern, and not really knowing what is actually causing the fault. I don't have the time/money for that.
Now, that being said, I have everything back in place as it should be and double checked all connections. And, it seems that all I am left with now is the Component Protection on these modules, at least I think so anyways, and I'm not 100% sure how to go about eliminating that.. That's where I stand on everything. Any comments, questions, or concerns are welcomed. As busy as life has been lately, and the weather being absolutely too much to take for any period of time, it's been hard to get back to working on it again.
The attachment has the 2 fault codes I was getting, before I sent the modules off for repair, if you can see it clearly.. And now that I've installed everything and cleared the codes. These 2 codes do not return, so to go back to your issue, once you get your wiring stuff sorted, you may come across one or both of these same codes as well. Okay, that's all I have time for right now. Let me know how things are coming when you get a chance.
