So I would like to flash a new parameter set to the A5 front camera (the one in the windscreen) to enable some functions like Stop&Go and TSR - does anyone know if this will dis-calibrate the camera? i.e. will it be required for it to be calibrated again? I know you need to re-calibrate if you flash new firmware but I wonder if it's the same (or not) when flashing parameters. It was a proper PITA to calibrate the camera last time.
