You may find that they aren't available because of the way that the spacers need to be packaged in terms of the hub that it's sitting on and enough of that being available for the wheel to get onto as well. Not saying that's the case but I've seen it before. Why are you specifically looking for 10mm versions if you don't mind me asking? The 12.5 and 15 mm versions have been pretty widely used and tested now.I’m struggling to find good quality 10mm spacers for the new RS3.
12.5 and 15 are quite common, but where can I find 10’s?
Thank you for your suggestions
Thank you, I see your point.You may find that they aren't available because of the way that the spacers need to be packaged in terms of the hub that it's sitting on and enough of that being available for the wheel to get onto as well. Not saying that's the case but I've seen it before. Why are you specifically looking for 10mm versions if you don't mind me asking? The 12.5 and 15 mm versions have been pretty widely used and tested now.
Fair enough. Just on a quick Google and looks like you might be able to get them here:Thank you, I see your point.
I’m specifically looking for 10mm because I only want to give a slight touch to the rear axle.
The front looks ok to me as it is, and I’m not planning on lowering the car.
Thank you.H&R 10mm spacers with bolts - current price £114.00 inc. VAT
Damian @ DPM Performance
PCD and bore is the same so you're good.Thank you.
On the compatibility chart I can’t see RS3 8Y, only 8V… can you confirm these are the correct ones?
H&R Trak+ 10mm Hubcentric Wheel Spacers & Bolts | Audi | RS3 | DPM Performance | PN2055573B|5903
Buy the H&R Trak+ 10mm Hubcentric Wheel Spacers & Bolts for only £114.00. Fits RS3 8V (2015-2019)www.dpmperformance.co.uk
My only suggestion is, If you insist on spacers at least go thick enough so you can use hubcentric ones.
You have an RS3, not exactly a car to take chances with
I do wonder at the wisdom of ‘playing’ with spacers in that they are effectively pushing a unsprung rotating mass further away from its designed position on the car.
Could be but my money would be on one too many meeting faces to get crap on, damaged or out of square etc etc. I would love to check the final runout on the wheel rim with a dial gauge.
I have no real objection to spacers if done right (Porsche put them on couple of cars OEM) but my preference has always been to get the wheel with the correct offset to do what I want.
My issue with spacers is the added shear force on the bolts at the hub face and that tends to be the point of failure. Helped by hubcentric spacers if one stud fails (or thin enough to retain some lip) Not helped by the questionable quality of the extended bolts supplied (even by some of the better manufacturers)
Mine appears to have developed a vibration at motorway speeds. Shakes the car rather than just the steering wheel so I feel like it's something more significant than just something to do with my spacers, especially as it comes and goes like something is harmonizing rather than it just being there all the time like a bent or mis-mounted wheel or something. I've had my spacers on since day one and this has only just appeared recently after around 9k miles, so it's booked in to be looked at.There was just yesterday a post by an 8V owner regarding spacers on Fudbook
He’d put them on the car and was complaining about vibration at speed, which as I’ve experienced is usually a wheel balance that’s amplified by pushing the wheel further out from the hub.
However he was certain it was something else on the car even though the vibration wasn’t previously there.
Yeah I've actually taken them off completely, cleaned up the hubs and tested the car without them fitted just to eliminate them as the issue before I called Audi. I'll also be taking them off before it goes in so they don't try to use that as an excuse to not really investigate.Problems on the rear don't always show through the steering. Have you checked the torque on the wheel bolts? Alloy wheel spacers can expand and contract with the heat cycles loosening the studs.
When you add spacers you are adding a lot of material between the wheel and hub face on top of just the thickness of the disc, doubling or sometimes tripling the possible expansion.
Be curious what they find.
