Hi there. First post in this section as I have come from a 1.8t to A4 b7 avant brd tdi
Cut a long story short I had bent valves and broken rockers due to the tensioner giving way.
I've retapped M10 to m8 stud conversion, new idlers, waterpump,belt etc and I have rebuilt the head with new valves, rockers, cams and valve stem seals head gasket l and new tandem pump gasket and all the other gaskets, manifold egr valve/cooler
Car is all back together now but I'm sure it's not right. I've took it a drive and all seems well on that front but everything up top feels really hot. The tandem pump, fuel lines to pump the fuel filter, intake manifold and the egr cooler are all really hot.
I don't remember it being this hot. Am I overthinking this or do they all get very hot?
Measuring block 7 @90c is saying fuel temp 80c and intake temp 30c
Also when it's as hot as what it is bearing in mind it's not overheating coolant wise and fans are kicking in as they should , its like because it's hot it makes it really sluggish to start, like it's got a flat battery but fine from cold.
Battery and alternator are fine as I've checked with a tester.
Can anyone help please
Thanks for your time.
