I just had an incident with my 2022 Audi RS3, mileage is 22K kilometers (around 13K miles). I had a warning in the display about low coolant and to switch off the engine. Obviously I did immediately and let the car cool off. I checked the coolant and it was indeed a bit below minimum. I filled up with the appropriate coolant (G12evo) to the max line which turned out to be around 300 ml of coolant (1/3 litre). Checking underneath the car it does not seem to be leaking so am a bit worried about this. The car is still under warranty so will obviously book it in with Audi, but just wondering if this rate of using coolant is within "normal".
