Hi all,
I have a 2019 a5 sportback and the climate control in the rear has been acting up.
The climate control would be all synced (3 zones) and with the temperature set to 19 degrees, the front would be pushing out cool air and the the air vent in the rear in the centre is blasting out pipping hot air.
I have ran VCDS and I get the following fault:
1 Fault Found
328019 - Motor for Rear Right Temperature Flap
B10D6 07 [009] - Mechanical Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 118
Mileage: 72247 km
Date: 2023.11.11
Time: 20:03:50
Rear temp. door motor: specified value: 9699
Rear temperature flap motor: actual value: 11573
System run time-Engine running time: 419 s
System run time-Terminal 15 on: 447 s
Rear temperature flap motor: diagnosis-Last operating state: No routine started
Rear temperature flap motor: diagnosis-Operating condition: Blocking handling
Voltage terminal 30: 14.86 V
Outside temperature: 10.00 °C
Does anyone know where this rear temperature is located so I can swap it out?
Thank you in advance!
1 Fault Found
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 118
Mileage: 72247 km
Date: 2023.11.11
Time: 20:03:50
