in this episode I will be showing you how to remove and fit a VIS free wheel balance shaft delete on my mk2 Audi TT EA113 engine along with fitting a new oil pick up pipe VIS Motorsport Balance Shaft Freewheel Deactivation Sprocket - 2.0T FSI EA113VIS Motorsport's oil pump sprocket replaces the weaker OEM VAG two-piece sprocket (06F105243C) found on the TFSI Engine.This sprocket can be used for oil pumps with a balance shaft delete, or alternatively can be used to deactivate the balance shaft by removing the main cog inside the oil pump.
View: https://www.youtube.com/watch?v=SQC0IUlBfwE&ab_channel=CarChris
