- Joined
- May 17, 2017
- Messages
- 106
- Reaction score
- 15
- Points
- 18
Hi Guys
Had my engine replaced a few weeks ago and was running great until this week .
Now got an engine management light this week saying egr insufficient flow .
scan attached.
egr valve and anti judder flap was brand new febi bilstien 600 and odd miles ago and mechanic said it was still clean when swapped over from broken engine.
does the egr cooler on the cba engine have an actuator like the egr valve at the front of the engine.
also showing glow plug circuit fault but cant see any lose wires .
cheers
Thursday,11,January,2024,13:43:28:11420
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: Mileage: 232440km-144431miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2.0l TDI G000SG 9978
Revision: --H01--- Serial number: AUX7Z0H5FNQ0CR
Coding: 0000072
Shop #: WSC 59051 002 1048576
VCID: 75B7EDB1F9C3FF620C5-8020
VINID: 9D196AAAA2201494400080891092A7B35B
2 Faults Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 232184 km
Time Indication: 0
Date: 2023.12.16
Time: 15:07:56
Freeze Frame:
RPM: 1518 /min
Speed: 52.0 km/h
Voltage: 13.98 V
Load: 14.9 %
Load: 29.4 %
Mass Air / Rev.: 260.0 mg/str
Mass Air / Rev.: 530.0 mg/str
001652 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 232212 km
Time Indication: 0
Date: 2023.12.17
Time: 13:45:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Temperature: 10.8 C
Bin. Bits: 00110000
Time: 2.16 s
Temperature: 10.8 C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 1342401249220002C80D02ED921D0082390000
Shop #: WSC 01357 011 00200
VCID: 76B5EABDE8C5F47A05F-8022
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH08 0100
Revision: 000396 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72BDD6AD88ADE85A297-8026
1 Fault Found:
01273 - Fresh Air Blower (V2)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 232409 km
Time Indication: 0
Date: 2024.01.02
Time: 16:04:34
Freeze Frame:
Temperature: 8.0 C
Speed: 0.0 km/h
(no units): 137.0
(no units): 248.0
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008586638
Coding: 8DA82FA1B0141380EF00001C0000000000094E056401020E00A800000000
Shop #: WSC 06314 123 08192
VCID: 48C95445DEB1328AA73-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
scan attached.
cheers
www.Ross-Tech.com
VIN License Plate:
Coding: 0000072
2 Faults Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 255
Mileage: 232184 km
Time Indication: 0
Date: 2023.12.16
Time: 15:07:56
Freeze Frame:
RPM: 1518 /min
Speed: 52.0 km/h
Voltage: 13.98 V
Load: 14.9 %
Load: 29.4 %
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 232212 km
Time Indication: 0
Date: 2023.12.17
Time: 13:45:30
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 11.78 V
Temperature: 10.8 C
Bin. Bits: 00110000
Time: 2.16 s
Temperature: 10.8 C
Revision: 00H31001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 52
Mileage: 232409 km
Time Indication: 0
Date: 2024.01.02
Time: 16:04:34
Freeze Frame:
Temperature: 8.0 C
Speed: 0.0 km/h
(no units): 137.0
(no units): 248.0
