Jamestnewson
I've got an issue with my rear demister which doesn't seem to be working.
I've taken the rear trim off and tested that there is continuity in the circuit across the window and also that there is continuity in the wiring loom from the left to the right side connections, but still no joy.Has The 30A fuse is good and I was wondering if there is a relay which controls this hidden somewhere. The light on the switch works when pressed so I guess I might need to also test the switch for the voltage when on.
Anyone else had this issue? I assume the wing mirrors need to be in the central switch position for these the defrost too.
Cheers for any responses, it's appreciated.
