I don't have access to Elsa, but I have a 67 plate and have followed advise on here from very knowledgeable people.Help needed please. Having a disagreement with a dealer over mismatching tyres on car. Can some with access to Elsa PLEASE help by posting the tyre requirements for RS3 8V FL
67 Plate.
Help needed please. Having a disagreement with a dealer over mismatching tyres on car. Can some with access to Elsa PLEASE help by posting the tyre requirements for RS3 8V FL. 67 Plate.
13.9.2 | Models with transversely installed engine |
There wasn't one....not online the owners manual mate... the one that is in the glovebox.
Thanks Northpole. I've looked in the online manual which is linked from the My Audi app but it has no information about recommended tyre makes beyond the general stuff on tyres and rims
You are the judge of that in the end but you should not run rake or reverse rake if you have a quattro. The only model that doesn't care about that to my knowledge is the Q7 as it runs a torsen (continuous) 4wd system instead of the audi quattro system.Audi usually spec a R01 / R02 / A0 tyre.
I’ve ran several non OEM spec tyres on several RS3’s and never had an issue or had it mentioned on a dealer visit.
But yeah when buying a quattro all 4 tires should be the same brand, size, width and height.
Mweh they do it for the looks, it doesn't mean the car isn't level... put it on a level floor than put that same level ontop of the roof right in the middle of the car... it'll be level or just within spec. It's once it has more than 15% rake or reverse rake when the quattro system starts acting up. which you won't notice in the beginning but after a few years... excessive ware on the parts of the quattro system (i've seen this first hand on a few older mk2 TT's)RS3 runs staggered set up so that’s not strictly true.
So before finally agreeing to the tyre swap I wanted to check what Elsa Pro specifically says about tyre circumference differences between front and rear to make sure the the 255/235 GY Eagles will be in spec.
That all said, wider rear tires on a RWD car makes sense, not on a 4wd car.
Rake is when the front is lower than the back, reverse rake is when the front is higher than the back this is best solved with suspension tweaks. back to what you are actually talking about: It's called staggered tires and the reason for it is tracking. Wider tires on the front than rear makes it reverse staggered .
IMHO there is no need for the rs3 to have staggered tires... as long as the fronts are the right size to battle the understeer the rears can be the exact same size.
Michelin Pilot SS 235 vs Pirelli (R01) 255
I know what rake and stagger is thanks What I am saying is you cannot see either on two RS3s even if they are side by side as it is only a matter of a few mm either way. Most of the 1/2" extra width on the front is on the back side of the wheel anyway . Not done for looks, you can't see it.
I don't disagree, they could indeed be the same size. I run two sets of square and it works just fine, Square tyres are what the haldex should have, Staggereds were a band-aid on an old design for 9/10 round the Nürburgring for which the iron block RS3 needed bigger front tyres for understeer.
However they could not fit bigger rears due to the body design on the SB. I get away with it on the saloon but I only run 245 as they are PS4S and they are a wide tyre, about as wide as 255 in most other makes.
Anything more on the rear and it may rub, certainly would not pass type approval for a new car. That is why they came with 235 on the rear They have to add a plastic arch extension to the rear quarter for the 235 as it is.
I have a good shot of the difference in rolling radius between the RO2 and non RO2 Pirelli I will try and dig out, difference was about 10mm IIRC .
Because they put it on one side no surprise it caused me problems, 10mm difference across the axle
255 PS4S was worse which is why I went 245 all round, happy haldex now, especially with fresh oil
I’m tempted to buy a set then I can run 245 all round on the 8Y.
