Facelift LED high beam fault
Daimeon
Christchurch
Hi new to the group needing help please. I have a 2018 a3 in at my work. Left LED hi beam does not work I swapped the light from left to right and it works in the right side so I thought a wiring problem but the fault code moves from left to right side it has code D6-Light control left 2
C11FF13 supply for high beam -open circuit
Check the headlight actual wiring connector for any corrosion or damage to the pins 1st as it works now but still shows an error,which to me sounds like a bad connection somewhere inside the headlight itself.
Reactions: northpole
Hi I have checked all the pins etc even fitted a new light but still no high beam on left just very weird that it works on the right side but the fault code changes sides
51
5K
25
12K
MrFlibble
M
D
3K
