Power Steering Advice
DCooksey
Hi there and hope someone in the know can help! As is usual no doubt, I have a problem and done some reading up to see what I've cocked up!
I have an A4 Avant SE on a 'y' plate, which I've had for a couple of years now with no real problems. During that time I've kept the power steering reservoir topped up with oil from Halfords or the like (I know, I know - NOW that it's a problem!!) It has used a bit, but not a great deal.
I have just changed the disks and pads on the car and when sorting the offside front, I noticed that the steering boot was weeping and the area was 'oil damp'.
I've read through a load of posts under searching threads, all of which appear to be related to the A3, which offer a number of points of view.
What I would like to know, or at least get some idea is answers to the following
1. I will obviously start using the mineral oil from here on it to top up the fluid, but I guess the seals may have already suffered. How big a job is it to renew them - if it's possible at all.
2. Is is possible that both pump and rack will need to be replaced? Steering seems to be fine at the moment with no whines or rattles - just concerned that I may have an instant steering problem when I least expect it!
3. If I do need to overhaul/replace - how big a job are we talking? Is is something that can be tackled on a flat surface, or do I need ramps etc?
I didn't want to loosen the steering boot, just in case I made the problem worse - but I do want to get it sorted!!
Thanks in advance guys!
Darren
Personally I'd just keep topping it up. You're looking at about £400 for a new rack (recon exchange) and it's 7 hours labour at a VAG specialist, so a real pig of a job.
Mine had to be done as it was literally pouring out, masses of smoke coming off the brake discs/exhaust etc
You might find it doesn't necessarily get worse.
If you want the procedure to change the rack send me a pm with an email address and I'll get it from elsawin for you
Thanks for that Andy - will keep topped up in the meantime and look into replacement for when it goes - any idea on replacing bushes and seals??
Enda1 - you have a pm!
Darren
Hi Enda.
Welcome to the forum nice to have another irish man here.
Would it be possible to get a cd of elsawin of you?
I use version 3.3 that I bought of ebay, forget who I bought it of. I could copy them for you but not sure if this will work.
LOL sorry it was late last night and I thought it was your 1st post now I see that I was looking at how amny times you were thanked.
So is there some sort of security on the cd?
I've no idea but if pm me with your address i'll give it a try, only thing is it'll be next week before i get a chance to try it, I'm heading back up home to Derry for the weekend so will be without computer and internet etc.
Info received with thanks Enda - Cheers mate!!
Darren
731
549
805
