rocker cover keeps leaking
S3SYD
London
why does my rocker cover keep leaking oil??:keule:
i have changed the gasket twice..:wacko:
parts were from euro car parts:wtf:
any one help...:blackrs4:
hi s3syd,
i have read somewhere that the fuel injection pump develops a problem and pressurises the engine, thus putting the rocker cover under extreme pressure and therefore leaks. check out your sump oil for deisel contamination. i hope i have not worried you too much, but it needs checking out. good luck, barney.
hi s3syd,
i have read somewhere that the fuel injection pump develops a problem and pressurises the engine, thus putting the rocker cover under extreme pressure and therefore leaks. check out your sump oil for deisel contamination. i hope i have not worried you too much, but it needs checking out. good luck, barney.so sorry you drive a petrol audi in that case i don't know.
hi s3syd,
on second thoughts your crankcase breather may be partially blocked thus pressurising the sump in turn pressurising the rocker cover making it leak.
hope that helps.good luck, barney.
as you look at the engine on the right hand side by the back
