Right..sun was shining and went EuroCP. They ripped me off and charged me �205 but didn't care as i had to get the part in today as otherwise, I'd never do it.
Firstly i disconnected the battery....
The part to change:
Got the part:
Got the part off. Three screws and the hose clip. Also removed the air intake for the air filter and undid the oil dipstick to get better access. To get to the third screw at the back of the IMF, i had to get my aunt to hold down the thick pipe so i could undo it...
Here's the Old Part (really dirty considering a cleaned it a few weeks ago!):
Got the New part in (it came with the rubber seals so didn't have to buy anthing else...thats one of the reasosn i left the EGR valve in as i didn;t want to waste precious pennies on seals! (Im starting Uni Next month!)
There's a seal on the thick black pipe, i changed this when i cleaned it out so didn't see the point of changing it again (�3.30 from Audi - whata rip!).
The thick pipe just pushes in. You line up the bits that stick out and push it in and then clip it into position. On my part, the clip doesn't come out but pulls about a cm and then you push it back in when the seals in place.
Changed the F8 Fuse (The red one behind the big relay thing that says 458) - 10amp: (also connected the battery after changing the fuse)
Put all the other bits back on....Took it for a whiz and all the lights went off that came up when i put the battery back on (traction control, steering etc.) went off
Came back and Vagcomed it.
The Fault codes still came up:
3 Faults Found:
19558 - Motor for Intake Manifold Flap (V157): No Signal
P3102 - 000 - - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 92.0 Nm
19557 - Motor for Intake Manifold Flap (V157): Open or Short to Ground
P3101 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 92.0 Nm
17075 - Fan 1 Control Circuit: Short to GND
P0691 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00101100
Temperature: 90.0�C
Duty Cycle: 9.6 %
ERASED DTC'S AND THEN....SEEE FOR YOURSELF
Friday,22,August,2008,20:02:49
VAG-COM Version: Release 607.3-UD
Chassis Type: 8P - Audi A3
Scan: 01 02 03 08 09 0F 15 16 17 18 19 22 25 36 37 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: WAUZ-------------
Address 01: Engine
Part No SW: 03G 906 016 DT HW: 028 101 189 2
Component: R4 2,0L EDC G000AG 5878
Coding: 0000078
Shop #: WSC 06314
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Part No SW: 02E 300 041 N HW: 02E 927 770 AD
Component: GSG DSG 041 0813
Coding: 0000020
Shop #: WSC 06314
Address 03: ABS Brakes
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
Shop #: WSC 06435
Address 08: Auto HVAC
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Address 09: Cent. Elect.
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0000
Coding: 01884F00A2141000000000000000000000
Shop #: WSC 00000
Part No: 8P2 955 119 B
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00000
Address 15: Airbags
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0011602
Shop #: WSC 06314
Address 16: Steering wheel
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenks�ulenmodul H11 0020
Coding: 0011142
Shop #: WSC 06314
Part No: XXXXXXXXXXX
Component: Lenkradmodul H03 0040
Address 17: Instruments
Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
Component: KOMBIINSTR. VDO H71 0210
Coding: 0000408
Shop #: WSC 00012
Address 19: CAN Gateway
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Coding: 3F0F0B42070101
Shop #: WSC 06314
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 16
Reset counter: 65
Mileage: 95270 km
Time Indication: 0
Date: 2008.08.21
Time: 01:51:55
Address 25: Immobilizer
Address 42: Door Elect, Driver
Part No: 8P0 959 801 E
Component: Tuersteuerger. H10 0030
Coding: 0000048
Shop #: WSC 06314
Address 44: Steering Assist
Part No: 1K2 909 144 G
Component: EPS_ZFLS Kl.10 1301
Address 46: Central Conv.
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008000186D288505489AC63000
Shop #: WSC 06314
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H03 0010
Address 47: Sound System
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Address 52: Door Elect, Pass.
Part No: 8P0 959 802 E
Coding: 0000048
Shop #: WSC 06314
Address 7D: Aux. Heat
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
End --------------------------------------------------------------------------------------------------
Bingo
Sall sorted out and as for the radio fault code, thats there because i got my aftermarket Alpine in it!
There was also the bulb in the boot which had blown so changed that too..That fault registered on VAGCOM too but once bulb changed and code erased..taht was gone too..
My cars running sweet again with no yellow engine management light (MA). No rough idleing and the turbo sounds different (like its getting more air through it - healthier basically)
I'm a happy laddy again
A Big Thanks to everyone who helped me out on this one! (helping finding the prob, the part, the TSBs, etc.) Thanks guys and you know who you are and seriously guys, i really appreciate it
