leaky sunroof
putang
I was wonfering if anyone has had a problem with there sunroof leaking on there s3.
It has been pretty wild up here in scotland and i have had water coming in through the lighting unit above the rear view mirror.
Anyone had this problem before?
Not had this problem on my S3, but used to used to have this issue on my old Mk3 Golf.
It was blocked drain pipes. Quite a easy fix, simply run a length of wire down the tube and this should then dislodge the offending item. Be careful not to use too stiff a wire and be careful not to be too aggressive with it as you may dislodge the pipe and it can be a headache getting that reconnected.
607
973
10
5K
