S3 Spacers or No Spacers?
DaveS3Turbo
Sepang Blue S3
Hi guys,
I'm not really a techie when it comes to modding a car.
Obviously I know whats what but don't know the adverse affects.
What spacers do ppl fit to the S3's, are any before/after pics.
David
As stated above, 10mm front, 12mm rear. Looks great.
what about if you go for a BBK? some says fronts will need 12mm spacers? then are the rears will be 15mm or both 12?
Dependent on suspension fitted I think as even the screw isnt a perfect solution, still rubs & only 12mm rears is safe bet.
Anyway Damian did you get a price for the B6's fella?
Does it bring the wheels out alot. I mean in terms of looking at it
Dave
well 12mm not huge amount, 15 is better but rubs so depends what your suspension is, 15 with rock hard suspension would be ok as wouldnt travel enough to rub, but I'm assuming you dont want a rock hard **** ride, I personally wanna bring the arches out more so I can run 15-20's but have to talk to someone else about that, of course wider spacers more stress on the shafts
Deleted member 21388
D
21
14
21
12
980
DPM
