Cost of repairs
Slick S3
Just to see hwt you guys think of these prices i got quoted from an independant audi specialist....prices include supply of part, fitting and vat.
Front top suspension monutings and bearings £168
front anti roll bar and bushes £178
rear anti roll bar and bushes £164
both cv gaitors on osf driveshaft £150
outer cv gaitor on nsf driveshaft £129
pre catalist lambda probe £211
Throttle body clean and set £68
Its a shock to say the least, what bits would be i be better off buying myself and getting a local mechanic to fit.
Any feedback would be great guys:sm4:
I did front ARB links a couple of weeks ago. £116 including labour, and using genuine Audi parts.
Not done any of the others...
that does sound a lot for just cleaning the throttle body, but unfortunately i don't have a vag-com! thinking of buying one though.
are you replacing the ARB with a uprated one either R32 or H&R ??? It seams strange that the front and rear are amost the same price as the rear is easy to do and takes at least 1/2 the time of the front one. Deffo worth upgrading them as the std one is sleved and that splits on the S3 whereas the R32 one isnt sleved. (same bush used for both )
also only £21 difference between 1 cv boot and 2 .... seems odd but maybe he hasn`t itemised it all correctly.
top mounts take almost as long as fitting new spring and shocks so sounds about right.
a lot of those jobs are quite easy DIY stuff, Front ARB is the hardest of the lot probally.
cv joints require a tool to do the clamps up that hold them on and it can be tricky doing the CV boots if things wont come apart like track rod end nut.
I need to get some similar things to what Slick needed so i got a price for top mounts: £82.50 + VAT per side, front Driveshaft CV Boots inner and outer replaced: 109+VAT per side.
Seems pretty cheap compared to above, and that was Inde Tech in Milton Keynes. If I had ramp, i'd have a go myself... never mind!
15
19
A
4K
882
