Heater help
Crashlanding
Age
42
Middleton, Manchester
Hello,
Blower motor packed up, cleaned with some WD40 and it worked again for a bit now its gone, i have read that you can replace the brushes, would this fix or should i get a new one?
used are £40
New are twice the price!
Brushes are £15
Help!
it could also be the wires that feed the connector on the back, my old A3 had issues where i tied the wire back on itself to temporarily fuse the connection...which had obviously broken within the wires sheething
No it'll be the brushes as usual.
I tried the replacement brushes and found them noisey, so replaced the whole unit. Count yourself lucky, I had to spend 180 quid on mine (as it was a while back before ebay). The brushes should work fine if you are handy with a soldering iron.
What replacement brushes did you use?
If you use these ones then they should be fine. I used these in my Passat and they're perfect - as good as OEM. (There's a way you can fit them without needing a soldering iron but you need to cut a wee bit off the end of the brush)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=190267018046
9
922
481
5am
438
