Coolant top up
Clach
A3 - 1.8Ts
Oxford
Had the dreaded low low coolant symbol this morning, with the cold weather...May be a silly question ask but when using G-12 to top up do I need to add 50% water at the same time, or is it already mixed in?
Cheers in advance.:salute:
I Mixed the g12 mate with water as it isnt mixed straigh out of bottle.
I just filled empty bottle 1/2 and 1/2 g12 and that done the job perfect...
Read the bottle for the mixture %. Should be done correctly esp with the cold weather. You need to mix water with it though.
40 coolant or 40 water...I hear the non-static water or something like that is the stuff to go for out of halfords...
should be 40-60 % strength so either 40 ml coolant per 100 ml of mixture up to 60ml of coolant per 100ml of mixture. I use a old screen wash bottle fill up to 500ml with coolant then fill to 1 ltr mark with water hey presto 50% mixture.
746
755
681
759
imported_oilman
I
