Error code
dieselfitter251
Blow ma own trumpet?
High 'C's
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D73
Coding: 04144
Shop #: WSC 06325
2 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
01273 - Fresh Air Blower (V2)
17-00 - Control Difference
Anybody know?..Is my blower goosed or it sensor or something?
here is the label file for that code if you havent already sean it.
Possible Causes
  • Fresh Air Blower (V2) defective
  • Control Module for Fresh Air Blower (J126) defective
  • Wiring defective
Possible Solutions
  • Check Fresh Air Blower (V2)
    • Perform Output Test (Check Air Vents while Blower is active)
    • Check Meas. Blocks while Blower is active
  • Check Control Module for Fresh Air Blower (J126)
  • Check wiring
Retrieved from "http://wiki.ross-tech.com/index.php/01273"
3K
J0N
NHN
4K
12K
787
