The engine mounts won't really help on the gears changes but fitting a stiffer (possibly Neuspeed) dogbone bush will help alot.
I have not so long fitted mine and allthough it is rougher on idle and pulling away at the moment it is much smoother and of cause you get less wheel spin and zero wheel hop.
Apparently when the bush beds in it becomes alot smoother.
I have the forge one thats been on for about 6 months and it still hasnt settled. It is still rough at idle and the car vibrates alot more. Also need more revs to pull away! Didnt notice a difference in gear changes. Im going back to standard at weekend.
