The botton axis is rpm, and this matches, from 2k to just over 6k, with the side axis being lb/ft and bhp respectively. My graphs actually cross at around 4500 rpm.
Probably means nothing, I am far from an expert on dyno graphs.
Dunc,
What I meant was, the numbers on the y axis should be identical (the unit being the same as the formula) to be able to compare.
For example 200bhp and 200lb-ft should be on the same horizontal lign. if not they're not gonna cross at the right point
Just to add: if you do what I said above the curves definitely have to cross at 5252rpm as when I asked AMD they confirmed that they only measure the torque then calculate the bhp with the formula you mentionned above. If not then there is something wrong with the RR
[/ QUOTE ]
Steph, you are quite right - bit of a blonde moment I'm afraid - the curves do cross at 5252 rpm /ubbthreads/images/graemlins/beerchug.gif
i have a video in richA3Turbo's car, i will send it you rich so you can edit any bit's you don't want show on here, i don't want the 05 taking you to court, come to think about it the only bit you can post is pulling out the car park /ubbthreads/images/graemlins/angel.gif
if it helps dunc my car lost 59bhp through the transmission roughly 25% of estimated fwhp.silvers3 you're definetly running 1.5+ bar,it's a shame amd couldn't plot this on with the graphs as it does give a good indication of whats happening.
[ QUOTE ] Ryanc said:
Just out of interest rich,whats holding your car back from making more torque and bhp.Are you just being conservative with the boost?
[/ QUOTE ]
Mechanical sympathy! Id rather change bits when i please rather than when they break. When ive done this, there will be a hike in power again.
[ QUOTE ] DickyS3 said:
I think xvw is doing a report for us. As soon as this is done, I will submit it to Audi Driver Magazine who said they may do a feature in their mag...
[/ QUOTE ]
Cool!
i did have the intention of taking loads of pcis, but kind of got side tracked!
[/ QUOTE ]
Cool!
Rich
[/ QUOTE ]
Gossiping like an old woman more like! /ubbthreads/images/graemlins/lol.gif
[/ QUOTE ]
/ubbthreads/images/graemlins/lol.gif too true! /ubbthreads/images/graemlins/laugh_roll.gif /ubbthreads/images/graemlins/beerchug.gif
