In relation to my previous thread (Which is currently down) :
http://www.audi-sport.net/vb/showthread.php?t=74559
So in typical ant and dec style:
"The results are in. Please don't phone in as the phone lines are now closed, your votes will not count but you may still be charged."
I had 4 Fault code, one of which i couldnt find an explination for:
4 Faults Found:
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
16395 - Shareware Version. To Decode all DTCs
P0011 - 35-10 - Please Register/Activate - Intermittent
17947 - Shareware Version. To Decode all DTCs
P1539 - 35-00 - Please Register/Activate
16705 - Engine Speed Sensor (G28): Implausible Signal
P0321 - 35-10 - - - Intermittent
Description of Faults:
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
* Engine shuts off
* Engine doesn't start
* Speedometer inoperative
* Glow Plug Indicator Lamp (K29) flashes
Possible Causes
* Engine Speed Sensor (G28) loose
* Engine Speed Sensor (G28) faulty
Possible Solutions
* Check Engine Speed Sensor (G28)
Special Notes
* The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position.
16395/P0011/000017 - Bank 1: Camshaft A (Intake): ****** Setpoint not Reached (Over-Advanced)
Possible Symptoms
* Power Loss
Possible Causes
* Camshaft Adjustment Valve 1 (N205) faulty
* Fuel Pump Relay (J17) faulty
Possible Solutions
* Check Camshaft Adjustment Valve 1 (N205)
* Check Fuel Pump Relay (J17)
Special Notes
* When found in Engine: 4.0l W8
o Check TPL 2010059(RoW)
+ Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal
Possible Symptoms
* Engine shuts off
Possible Causes
Possible Solutions
Special Notes
* The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
* When found in a VW Golf/Jetta (1J/9M) or Audi A3 (8L) with 1.9l TDI-PD (AXR), check TPI 2007067 which explains issues with electro mechanical interference. A modification to the wiring will fix this problem, extensive details can be found in the named TPI. Even though this TPI was originally released for VW Golf/Jetta (1J/9M), a customer of ours came across the same issue on an Audi A3 (8L).
* When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB number 97-05-03 or 97-05-04 calling for a flash update to the ECU and a secondary ground installation. This applies if ECU software version is below 6328; current software version should be 7000 or higher.
So what does this all meen?
4 Faults Found:
Possible Symptoms
* Engine shuts off
Possible Causes
Possible Solutions
Special Notes
Possible Symptoms
* Power Loss
Possible Causes
Possible Solutions
Special Notes
Possible Symptoms
* Engine shuts off
Possible Causes
Possible Solutions
Special Notes
