Ess_Three
- Joined
- Feb 19, 2001
- Messages
- 5,383
- Reaction score
- 20
- Points
- 38
- Age
- 52
- Location
- Aberdeenshire
- Website
- www.audi-sport.net
Since the nice men at Audi damaged my 18" BBS rims, I had to remove them to have them re-furbished...and instead of fitting my spare set of 18" rims I decided to go back to the standarsd 17" set up to see how the fully sorted suspension set-up copes with 17" wheels and tyres.
I've been running this set up now for a few weeks...and it's not very nice!
My other half first commented that there was something wrong with the car...it just didn't feel right. Investigation was required...
She's right...
The set up I have was optimised for 18" lightweight (lighter than standard) wheels...and going back to heavier wheels with higher sidewall profiles has not improved the the driving experience one bit!
I tried my usual test roads...and have come to the following comclusions:
The car 'floats' on the standard wheels.
It turns in reasonably well...not as precise as on the 18s, but sharply...but it doesn't offer the same level of feedback as the 18s did. You seem to turn in, not instinctively know how much lock to apply, and have to wind corrective lock on or off to compensate - not ideal. It removes the fluidity of the previous set-up with the 18" wheels.
Once pitched into a set of bends at a decent pace, the car is not so predictable...it tends to wander off line, requiring continual small corrections.
I doubt this is down to rubber choice as I found the standard Bridgestones at least equal, if not better than, the 18" Avons.
Next step, tyre pressures:
I tried upping the front pressures, to remove some of the flex in the sidewalls...no good...too twitchy.
I tried upping the rear pressures to assist the precision of the turn in...better...but not sorted.
I tried lowering the rear pressures...horrible!
Several weeks later I have come to the conclusion that my previous combination is vastly better. I had perfect turn in, no float, no twitchieness and plenty of stability.
Although the overall grip levels are probably equal...we (g/f and I) appear more confident pushing a bit harder with the 18" wheels fitted.
So, now the 18" multi-piece wheels are repaired and re-bulit, I shall be re-fitting them with the minimum of delay. Great!
She's right...
