That's exactly what I'm after ... get out the car, shut the door, and the car then locks/alarms after a set period. Mine doesn't do this, but I'm sure it's only a setting change via Vag,ccm?
No there's no setting for this in VCDS AFAIK. You're asking the car to recognise that you've removed the keys and left the car. Not impossible but open to problems.
As others have said, if I unlock mine, but don't get in, after around 20 secs it'll lock up again. You're right, if the car were to lock automatically after the driver's door has been opened/closed, you run a real risk of locking your keys in there! I don't have VCDS so couldn't tell you if it can be programmed to do that. It would scare me!
