As well as changing settings for retrofits such as cruise control and RNS-E there are certain settings can be changed on 8Ps with VCDS alone.
There are far more options than I have highlighted here but most either have no use, would be detrimental or just seem to have no effect to the car.
Feel free to add more if you know them :thumbsup:
If you don't know what VCDS is then have a read of
THIS.
09 - Central Electronics
Long Coding Helper:
Byte 0
Bit 3 - Daytime Running Lights (Scandinavia) active - (DRLs plus tailights)
Bit 4 - Daytime Running Lights (North America) active - (DRLs only)
Bit 5 - Assistance Driving Light _Leaving Home active - (Note 1)
Bit 7 - Coming Home active - (Note 1)
Byte 3
Bit 5 - Teardrop Wiping for Rear Window active - (Single delayed extra wipe after rear wash/wipe)
Byte 5
Headlight Washer Delay - (? x 50 = delay (ms)) - (Useful in the winter so you're not washing your headlights every 5 minutes)
Byte 8
Bit 7 - Daytime Running Light (DRL) Deactivation while Blinking active - (Turns off or dims (8P3) the DRL whilst indicating)
Byte 17
Bit 0 - Emergency Brake Flash Light active - (Hazards on when emergency braking)
Bit 4 - Daytime Light via Fog Lights - (For models without DRLs)
Bit 5 - Front Fog Lights deactivated with high beam
Byte 22
Bit 1 - DRLs switchable via menu - (Note 2)
Byte 23
Bit 1 - Advanced Comfort Menu active - (Note 2)
17 - Instruments
Coding:
xxxxx?x
0 = Seatbelt Warning Inactive
xxxxxx?
0 = Needles OFF and Scales Off
1 = Needles ON and Scales Off
2 = Needles OFF and Scales ON
3 = Needles ON and Scales ON (Dimming active)
4 = Needles ON and Scales ON
44 - Steering Assist
Adaptation:
Channel 001 - Steering Assistance - (For some models before 2008)
46 - Central Convenience
Long Coding Helper:
Byte 0
Bit 0 - Selective Central Locking (Single Door Opening)
Bit 3 - Auto-Unlock (Unlocking after removing key from ignition)
Bit 4 - Auto Lock (Automatic locking from 15Km/h)
Byte 5
Bit 6 - Comfort Function automatic closure - (The button doesn't need to be held down to close the windows/sunroof)
Bit 7 - Power Windows/Sunroof disabled after door opening - (Note 3)
Byte 6
Bit 2 - Comfort opening Power Windows via Remote Control
Bit 5 - Comfort closing Power Windows via Remote Control
Byte 7
Bit 5 - Comfort closing Sunroof via Remote Control
Byte 8
Bit 0 - Unlocking Confirmation (Blink) via Door Locks
Bit 1 - Unlocking Confirmation (Horn) via Door Locks (Note 4)
Bit 2 - Unlocking Confirmation (Blink) via Remote Control
Bit 3 - Unlocking Confirmation (Horn) via Remote Control
Bit 7 - Horn Configuration Blocked - (Deselect to make changes)
Byte 9
Bit 0 - Locking Confirmation (Blink) via Door Locks
Bit 1 - Locking Confirmation (Horn) via Door Locks
Bit 2 - Locking Confirmation (Blink) via Remote Control
Bit 3 - Locking Confirmation (Horn) via Remote Control
Byte 10
Bit 6 - Synchronised Mirror Adjustment - (Control both with driver setting and passenger only on passenger)
Bit 7 - Mirror Lowering with Reverse Gear (Only with memory seats) - (So far no one has done it)
Notes
Note 1 - CH and LH lights can be enabled on models with Bi-Xenons with just coding. For other models read
THIS or for models with LED DRLs read
THIS.
Note 2 - Advanced Comfort Menu allows certain settings to be changed via the DIS. These are as follows:
-Ext Lights
-Daytime Lights - (DRLs On/Off)
-Coming Home - (Time delay 0 to 60 seconds in 5 second increments)
-Leaving Home - (On/Off only. Delay can be adjusted in adaptations. Default 30 seconds)
-Wipers
-Front - (Service position On/Off)
-Rear - (Automatic on in Reverse On/Off)
Note 3 - This function works in reverse on my car. With this selected I can still open and close my windows once the door has been opened.
Note 4 - Enables alarm beeps when unlocking and/or locking the car.
Useful Links
http://en.openobd.org/audi/a3_8p.htm
http://oooo-a3.blogspot.com/
http://wiki.ross-tech.com/index.php/Main_Page
