Raising head light levellers
Andy_S3
Teesside
Since having the car lowered by 25mm my headlights seem to be facing more to the ground than usual. There not aiming right down and both sides are identical in position so im guessing the motors are ok. I read on here somewhere that to properly adjust the headlight levellers you need Vagcom. I have Vagcom so im just wondering if someone could explain the process? Its strange as the rear are of the car sits slightly lower than the front now so I thought the opposite would have happened - as in the beam would be to high!
You could also raise it with a screw driver, on the head lamps you will see two white screws on either sides.
As above, there are two white plastic screws on the light units, they need an allen key to adjust.
Get the headlights to basic settings and set on a beam setter, 55 is headlights but not sure on vagcom.
578
697
784
977
796
