Is that the uprated aftermarket Sachs clutch and DMF? as per Iggus car?
Is the pedal a lot heavier?
Long term I might go Stage 2(+) but my main reservation is the clutch & DMF, cost, and usability in rush hour traffic.
iirc Stage 2+ is around 2K (if you already have REVO Stage 1) but its at least the same again for the clutch & DMF.
Keep us posted on how you get on with the car, relaibility etc...:icon_thumright:
cheers
Paul
Hi Paul.....it's the Sachs and DMF as Iggu has already.
My OEM clutch just lasted a bit longer!
It is a bit heavier than the normal one,but nowhere near as bad as some race/competition clutches,and not as snappy either,so for road use with an uprated car,it's a good compromise.
Costs...IIRC...
I went straight for the Stage 2 which included the remap and the full Miltek exhaust,so that lot came to about £1500.
Stage 2+...I initially just had the HPFP added,so that was about £500,and then we had all the misfire problems at the top end,which eventually came down to the intake,so a Forge CAI and DV were added for about another £340.
The clutch was about £1400.
So...about £3700-3800 in all.
It's perfectly driveable around town if you treat the clutch with a bit of respect,and that's something my Escort wouldn't do easily,so it's a testament to how far ECUs have come over the last few years.
Driven gently it still does 33mpg,and the extra performance after changing the settings yesterday has given about 40bhp more(Shaun cut the boost and upped the fuelling when we were having problems so the power was cut right back).
Reliability right now shouldn't(I hope) be a problem,as there are a good number of other people running the same with no problems.
It's when you start running big turbo conversions that you can have serious problems with detonation and cylinder temperatures,and you also need to pay attention to uprated oil and water cooling.
As you know,a couple of people her have done that,and one has had problems with the car in his ownership,and the other(jonnyc) having sold it to someone and then bought it back,found the other guy had just ignored the maintenance.
My past experience with 2 litre engine running 400bhp is to have them built properly,by someone who's done it before and knows the problems,then look after it.....regular oil changes,synthetic every time,cool it down after a hrd run before switching off etc etc.
