No Drive!!!!
a3-tdi
Hello everyone,
Just bought myself a 53 plate 2.0tdi a3 and i got my first problem :crying:. The car start and goes into gear but theres no drive. The clutch pedal feels very springy and vibrates ALOT. dunnno what the problem is, whether its the clutch or something else?
Need Help!! :sob:
Sounds like the master cylinder...a bit of a sod but 10x better than a clutch !
:sadlike: nooooo, just bought a new cluth and flywheel! s**t,
Thanks neway
surely if it was either of the clutch cylinders then you wouldn't be able to get it into gear?
When you let clutch back out is there no difference at all, like in the revs etc? Did it give you any signs that the clutch was slipping?
To hazzard a guess, if there was no signs prior to this, sounds like the clutch plate could be seized on the output shaft.
I was about to say how did you get in gear without any issues.
It goes into gear without pressing the clutch, and there is no difference at all when i let the clutch back up just vibrates alot and feels springy.
344
914
