Ticking Noise
johnnyddaman
Hi
I have an S3 which has developed a ticking noise which is heard most prominently at, erm, tickover.
Speeds up and slows down with the engine revs.
Anyone know what this would be?
Ta
H
lift the bonnet and have a listen around the offside near the front, between the screenwash bottle and the engine coolant bottle.
remove the offside plastic cover (one phillips screw at the rear i think) and nestled between screenwash, coolant and power steering fluid bottles is a black box with a wiring connector on top. when i checked mine i could feel it clicking as well as hear it.
If that is where the noise is it is most likely from the charcoal filter, apparently a little solenoid there. I had it into see the audi mechanic when i heard it, turns out it wasn't a fault. you basically just have to live with it.
Ha ok. I don't have the car the mo, mum's borrowing it :redface:
Will check later in the week and get back to you.
What's a charcoal filter anyway? I thought I had an INTERNAL combustion engine?!
20
995
MPH
