Canbus chorus/ concert
Y83OLK
Hulk Smash!
Hi.
Currently i have a chorusII headunit (according to vagcom)
Is this canbus equipped?.
If it is, would it be the same pin config as a concert II (from an a3 8p)
...i believe all concert II's run canbus?.
Regards
Callum
Just ensure it's from an early 8P, as they moved from ISO to Quadlock connectors around 05
Thanks guys.. just what i wanted to hear, its from a 2003 so should be lovely.
Hi,
UI got the radio, all seems good, ill hopefully fit it at the weekend when i have a spare 5 minutes.
Can anyone confirm if this is quadlock?
Also, whats the square yellow connector?. as i think mine on the chorus is round.
regards
(sorry about the pic size)
No that's definately ISO. The yellow connector is the second antenna connection (ZF diversity switching lead using a Fakra connection).
I think you can just ignore it as the standard round ISO connection handles the main FM/AM signal. The Fakra one only works if you have the antenna module in the rear, which you won't.
I
13
927
