Hi scotty still trying to get rear door/puddle lights working , I put the code in above for both front and rear , front ones worked but rear ones don't
what dos it mean modules 62 left rear 72 right rear where do they go can you show pic or something desperate now lol kind regards David
Hello. I just finished doing the door puddle/warning lights + illuminated door handles on my 2012 a4 b8 facelift avant. I could not do the ambiante door pocket lighting as my door modules only have the half shaded box and no pin 3 (rear door 16 pin) or pin 8 (front door 32 pin) in the modules.
Did you connect your rear light into the right pins? Mines are as stated:
-front modules 32 pin:
Pin 3, door illuminated handles +12v
Pin 16, puddle/warning lights +12v
Pin 8, ambiante lighting +12v (N/A)
Pin 5, earth, just solder lights earth together on this brown wire.
-rear modules 16 pin:
Pin 1, illuminated door handles +12v
Pin 3, ambiante lighting +12v (N/A)
Pin 12, warning/puddle light +12v
Pin 13, earth, just solder together lights earth on this brown wire.
Then just go into each door controler and check the tick box for whatever lights you added to your car.
For the door handles i used 1 bright red 12v 5mm LED for each door handles. I drilled on the top of the handles where the original oem would be. Just sandpaper the led to diffuse the light. It looks great at night. I hope this will help you.
