TDI
t2myd
lancashire
my a4 tdi afn is coming up with needle lift sensor fault , will this throw the car into limp mode ive changed loads of sensors and this keeps comeing up
yeah ,cars running perfect now ,turned out to have a loose connection on the boost solanoid, loads of power now
I appear to have exactly the same problem. Stopped off on the way home from work and when I started the engine again the revs rose to just over 2k rpm for about a second before it settled to idle. Pulling away I noticed a lack of power and general sluggishness which I assume is limp mode. No warning lights or smoke under acceleration.
Did you need to do a VAG-COM scan to locate the boost solenoid problem, and is it easy to get to? I have no idea where this is in the engine.
Car is a '98 1.9TDi quattro AFN engine with 183k miles.
:yahoo: mine turned out to have 2 wires mixed up , realy got on my nerves for 6 months trying diferent sensors ,and puting it on vag com , pulls realy well now , especialy after the de,cat .was around 145 bhp with remap . definatly more now that turbos been cleaned and decated , If you need any sensors email me ive got some spare. tommydavieson@hotmail.co.uk )
I ended up biting the bullet and took it to a diesel specialist turned out mine was a sensor on the fuel pump?
there a brilliant car when there running perfect ,but when there not there a pain in the a@se .ive had mine 3 years ,it was justy a car a bought off my mate ,in fact ive never realy drove it , troubles started when i lent the car to a good mate ,and problems started from there
657
33
3K
700
