Blue_Thunder
Looks like the S4 could have another boost leak.
I've got my own pressure tester, but no compressor, so it means I have to either go to a garage forecourt (which are usually too noisy for you to hear small leaks) or head to somewhere like a Kwik-**** who aren't always willing to let you play with their equipment.
I've got a decent tyre compressor, but even though it claims to be able to inflate a tyre from empty in x minutes, it just doesn't seem to have enough puff to fill up the intake of an S4!
I've heard of people using their spare tyre to fill the intake. Sounds like a genius plan. If I did the initial pressurisation of the intake with that method (I assume you'd want to pump up the spare tyre to a failry high pressure first), I could then use my tyre compressor to keep it 'topped up' whilst hunting for leaks.
Can anyone think where I could get an air hose with a schrader valve on each end nice and cheap? Ideally the hose would be long enough to go from the spare wheel well to the engine bay to save faffing about.
