Tyre pressure
glenn-3.2
gone from 225/45/17 wheels& tyres @ 36psi f /33psi r to 225/40/18 as on 07> sports backs ,should i keep same pressures as the 17's ?
Glen
I run 38psi all round on 18's and i get even tyre war across the width. You will find it rolls better as well.
S-lines have 18 std and this is my petrol cap sticker
I was told by my wheel supplier to add 2 psi per size up, against what your petrol flap advises for your oem sized wheels
thanks guy's. the exact info i needed.cheers:thumbsup:
Glen
Isn't that for a 3door though? The OP says his is a Sportback, and the tyre pressures for my SB are different to your image.
Mine are something like 35/30 normal load up to 100kph or 38 all round for max load
I have a sport-back and have had the tyre pressure's from a 2.0 tdi sportback (s-line) 225/40/18 38 psi front 35 psi rear normal load or 41 front and back motorway and fully loaded.
Its only a ball park figure because strictly speaking the pressures are different for different makes of tire. I always run light but 38 all round works well with F1's
824
676
744
12
