2.0TDI Rev Counter, Startup and running issues......Bluefin?
PTTM
Pedal to the Metal!!!
Tewkesbury
Hey Peeps!
Im in need of your help once again. It seems my car is having a midlife crisis.
I have an '06 Audi A3 2.0TDI (140) DSG bluefinned!
I have just had the cam belt changed as I have reached 85,000 miles. Everything seemed fine after the work except there seemed to be a sudden considerable drop in mpg after getting it done. I thought the belt might need running in.
Now this Sunday, I tried to leave our church carpark and low and behold after turning the ignition on, the rev counter suddenly starts going berserk and jumping up and down all over the place. The engine would try and start but would not ignite. The yellow coil was flashing at me which ive read means something to do with a failure with the engine management system.
My thoughts jumped immediately to getting rid of the bluefin map and restoring it to original. I luckily eventually managed to get the car started and running somehow. Although it was far from being fine on the journey home.
I got home and turned the ignition off and then tried to restart the engine on multiple occasions - there seemed to be no problem?
I then got the bluefin unit and restored the original map to the car. Everything was fine with the car again.
So this evening I decided to put the bluefin map back on. Hell it was so noticeable that the bluefin wasnt on the car.
On my way back from Tescos ten minutes ago, I come round the corner and the engine completely cuts out on me and then the rev counter goes mental again same as before. The P-R-N-D-S also starts flashing at me. I chose to put the gear into N and cruise to a safe parking place. I tried restarting but had no luck. Luckily I had the bluefin with me due to the recent issues so I immediately restored the original map again. The car started fine and I drove home.
Question is....why is this suddenly happening now?
I have had the map on for a year - on and off due to servicing and Ive had no problems at all. Does anyone have any answers?
Any Constructive feedback is always greatly appreciated.
PTTM - Happy New Year
I had a flashing glowplug light on my dash ( my 2.0 tdi also bluefinned ) for the last few days. Car lost power, went into limp mode.
Took the map off with bluefin, read the errors with VCDS and had:
-18041 - Accelerator Position Sensor 2 (G185): Signal too Low
-17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
And some other less important errors.
The problems have not come back yet, but I want to give it a few days to see if anything happens.
Car feels slower but more smooth without the remap.
Maybe problems occured due to humidity or temperatures?
I was also thinking that battery might be on it's way out, as when I close the windows and keep the buttons pushed in the interior light flickers a little.
Without VCDS / VAGcom codes i would leave the car std and be happy with the reliability until you can contact Superchips directly. Its what you paid all that money for
I'd be very surprised if it is anything to do with Bluefin - but as others have said, get someone with VCDS to scan the car which should throw up why you're having problems.
you can read fault codes using the bluefin fella read your instructions that you got with it!
Thanks everyone - Ant, I tried looking at the errors through the bluefin. I plugged it in and went to extras and I only saw immobiliser. How do I get it to show me the fault codes?
Guys I forgot to mention. There were some error codes when I had VCDS plugged into my car when Hazzy Dayz were fitting bluetooth into it.
00716 - Air Recirculation Flap Positioning Motor
01403 - Glass Break Sensors, Rear
Any ideas?
Btw, anyone know why I have a sudden drop in mpg as well after the cambelt change?
I was getting 55-60 and now im averaging 37mpg most days. My driving style hasnt changed at all.
Is it the weather?
I would take it back to whoever put the belt on, as the timing could have been set incorrectly.
Right things have now gone from bad to worse. Obviously no garages are open over the christmas period so i have had to use the car. The car doesnt start very often, it just ticks over and doesnt turn on but when it does it starts with the Emission light (engine icon) on and it stays on after starting the car. The coil doesnt initially light up however after 2 minutes of driving that starts flashing at me. The car no longer revs over 3,000rpm and if i slip the car into neutral at any time whilst driving the engine will just completely cut out. It is also just cutting out randomly whilst driving. Anyone got any ideas?
I am gonna take it back to the garage who did the cam belt change, however im afraid they will say it wasnt the fact they fitted the cambelt wrongly it was something else so they can charge me. What do i do?
Phaaa... I'm not happy about what I'm reading here. I'm due to change the cam belt on the 5th and I also have the Bluefin installed. I'll try to find someone with a vag-com to check for errors before the change. I'll put back the original map. I'm thinking they have to make some calibrations or smth. and are guiding on the original settings.
I won't put the bluefin map back until I'm sure that the cam belt was correctly installed.
I have to agree with ben, sounds like timing to me overall, take back to garage who did belt & get them to resolve as how can it be the Fin if was fine before the belt changed.
657
939
