Same as mine - 18c or 64f, and then it goes to Lo.
When Lo is showing, I presume the air con (cold) unit comes on, without measuring the temp inside the car.
thats what i thought so its 18c or frezzzzzzzzzzzzz
hmmm.. when mine is on low it doesnt seem to freeze.... in fact it still feels quite warm.. think i may have an AC issue
If your air con isnt working then the red econ light stop on and stops the compresser from working, you need vag com to read the fault code and hopfully its a pressure switch.
A B7 climate control can be retrofitted, but as mentioned requires a mod to keep the heated rear screen working, Woorlord can help you with this.
Mine goes down to 16c then low.. with cold air blowing then. Didn't work up until a few days ago changed the G65 Thrust Sensor ( thanks pjm ) 5 minute job to fit. perfect.
thanks james thats the bit iv change and still not working
what is the G65 Thrust Sensor and where is it
